Wheel Weights
Fuddy Duddy
Lot of weight for the size. Recon they could be modified to use for front weights? I have a pair of 16" that have the four holes. They are
about 7 3/8" inches apart. New holes could be drilled and spacers if needed. Is that to much weight for the fronts? Price seems right
for the money. Course could be made to work for rears too. But I'm looking at them for fronts. What you think?
225 Pound Steel Tractor Wheel Weights
Probably combine weights.
If adapted for use on tractor front wwheels you will need GOOD power steering.
Dean
Something I have used for good cheap front weights on 16" wheels is Farmall Cub rear weights. They fit just inside the lip on the 16" rims and the 4 holes they already have lines up with the slots in most fronts. I used long bolts or threaded rod. Even the dished out part on the outside of the cub weight will line up with your valve stem for clearance.
Guess that would be the same for Suit Case weights too? I haul around 55 gal drums of water out to my newly planted trees. Would like to haul 2 at a time. But I guess that's out.
