Re: Jubilee Changed Starter Sol Starts w/o push switch
JMOR
09-22-2015 10:41:38
Quoting Removed, click Modern View to seeThose Ford & NAPA numbers should electrically function correctly, but the mounting bracket will be curved to wrap the starter motor curvature, whereas your NAA needs a flat bracket (NCA11450A, ST-53, S-53, SS-558). Do not know any TSC numbers.
GPaWard3
09-22-2015 10:55:39
 Re: Jubilee Changed Starter Sol Starts w/o push switch in reply to JMOR, 09-22-2015 10:41:38
Quoting Removed, click Modern View to see I'm a newbie to tractors, Does NAA = Jubilee.
JMOR
09-22-2015 11:19:14
 Re: Jubilee Changed Starter Sol Starts w/o push switch in reply to GPaWard3, 09-22-2015 10:55:39
Quoting Removed, click Modern View to seeNAA was called Jubilee for Ford's 50th anniversary year (1953), but other than emblems & name, 1953-1954 were the same NAA tractors.
GPaWard3
09-22-2015 11:26:01
 Re: Jubilee Changed Starter Sol Starts w/o push switch in reply to JMOR, 09-22-2015 11:19:14
Quoting Removed, click Modern View to seeThanks, Back to original topic. What would happen if I switched the BAT and Starter wires on the Solenoid I have?
JMOR
09-22-2015 11:34:16
 Re: Jubilee Changed Starter Sol Starts w/o push switch in reply to GPaWard3, 09-22-2015 11:26:01
Quoting Removed, click Modern View to seeCan't possibly say, because I do not know which of many solenoids that you may have.
GPaWard3
09-24-2015 04:46:55
 Re: Jubilee Changed Starter Sol Starts w/o push switch in reply to JMOR, 09-22-2015 11:34:16
Quoting Removed, click Modern View to seeChanged the Starter Solenoid to a NAPA ST53 worked great. Thanks for the help!
JMOR
09-24-2015 05:47:27
 Re: Jubilee Changed Starter Sol Starts w/o push switch in reply to GPaWard3, 09-24-2015 04:46:55
Quoting Removed, click Modern View to seeYou are quite welcome. Glad to be of help.
HCooke
09-22-2015 11:06:48
All Jubilees are NAA. 1954 NAAs are not Jubilees. Jubilees are 1953 NAAs.
