hydraulic pump 8n
boler76
viewing from underneath the tractor there is a plug just in front of the drain, how is it held in ? it is leaking and needs to be repaired ? Thanks
The tractor has a pipe plug to drain the rear end, a drain plug on the pump and another one under the transmission. Which one is leaking?
75 Tips
it isnt the drain plug that is leaking it is a plug in bottom of pump that resembles a welch plug , located just in front of the pump drain plug
That's not s plug. It's part of the casting. If it's leaking there, it's cracked. Plenty of folks around here are skilled welders and can tell you if it's repairable and how to do it.
75 Tips
