gas shut off bowl
GordyMN
I have a 49 8n. On 9-16 I posted a problem I had with leaky sediment bowl. Thanks for the responses. The bowl does not leak anymore. However, now I have gas coming out of the stem or shaft of the shut off wheel. Even when closed gas still leaks out. I looked at the “Service Parts Catalog” but do not see a gasket for the stem. Is there a gasket I can replace or what would you suggest for a fix? Thanks. Gordy MN
(quoted from post at 03:45:33 09/22/15) I have a 49 8n. On 9-16 I posted a problem I had with leaky sediment bowl. Thanks for the responses. The bowl does not leak anymore. However, now I have gas coming out of the stem or shaft of the shut off wheel. Even when closed gas still leaks out. I looked at the “Service Parts Catalog” but do not see a gasket for the stem. Is there a gasket I can replace or what would you suggest for a fix? Thanks. Gordy MN
For the stem seal I punch a 3/8" disc out of a old thick leather belt and burn a hole in it with a dremel tool...
