vidaliaman
http://i43.photobucket.com/albums/e378/laru9779/Tractor%20Wiring%20Diagrams/WIRE-12-51-1w.jpg
this is the schematic that i am using from my ford tractors site, i have the coil from napa that does not need resistor, i can turn the tractor over by using a screwdriver from push button stud to battery stud but push button does not work, the stud on the solenoid for the push button wire was very loose when i took nut off of stud but firmed up when tightening down. will i need to take tranny cover off to investigate push button starter? also how would i check continuity?
dave
dave
