I have an early 8n model, had knocking problems in the engine and started an engine overhaul, as well as painting on the way back
out. Starting at the beginning this is what I have done. I tore down the engine and replaced the #1 cylinder and sleeve,
everything else has been reused as it is in good condition. Painted and reassembled. First try: turns over well, but no fire, not
even a pop. So I checked electrical, spark on all plugs. Played with distributor, tried all options for timing and still no fire.
I checked gas, was getting gas to the carb but still nothing. It has a good flow of fuel, also used starter fluid and nothing
still. I removed the carb entirely and sprayed a touch of starter fluid into the intake and then finally had a pop, also a small
fire, so that wont be tried again. I did disassemble the carb and cleaned it thoroughly so I do not believe that is the problem.
Does anyone have suggestions on what to try next? Is it possible that when putting the crankshaft back onto place the camshaft
wasnt lined up perfectly? Would that do what I am explaining?
