Tom N MS
I know nothing about tire and rim sizes--so will a 4 X 12 tire fit an 3 X 12 rim? and work
like it is suppose to? Looking like 3 x 12 is the rim sold for a 4 x 12 Kubota L1500
Rule of thumb on most tires and rim is you want the rim to be 1 inch smaller as in how wide it is then the tire so in theory a 3 inch rim is just right for a 4 inch wide tire
12 is the diameter of the rim. 3 or 4 is the width. A 4x12 tire will fit on the 3x12 rim, but if you put the correct pressure in it, the tire will likely balloon out in the middle.
Any idea of what inflation pressure should be on the 4 x 12--don't see it anywhere on this new tire..Tks
