Re: Strange ford 8n voltage regulator issue
I missed some of the previous posts..
Is it not charging, but will motor?
Last on i had did that was a Lucas b circuit with a field fault.
If you then ground the field, does the charge jump up?
Have you tried jumperwiring the vreg to the geyt directly as a test for bad wires or ground reference?
Will Gen motor?
If it motors, have you tried bypassing reg field, first, then cutout, then both, observing inbetween?
