Zenith 13960 Carb
bmack95hd
While digging through a bunch of boxes of carb and governor parts I found a brand new Zenith 13960 carb. Any idea what it goes to.
[b:188bc4ee8c][i:188bc4ee8c]
GOOGLE says:....." New Zenith Replacement Carburetors for gas engines used on older ...... Lift Truck, Ford, 192, D2JL-H, TSX973, 13960."
Also went though my paperwork for 'Tractor carbs, by Zenith'
No such Zenith #, used on any of the Ford tractors.
At least in my paperwork.
YMMV!!! :roll:
Gary :?: [/i:188bc4ee8c][/b:188bc4ee8c]
The closest it matches up to are some of the John Deere Tractors that were origionally equipped with Marvel Schebler Carburetors. You might call Zenith Fuel Systems in Bristol VA. Phone # is 276 669 5555. Fax is 276 645 8696 or email <zenithfuelsystems.com>
DG & GB, Thanks for the info. Maybe I'll list it on the Tractor Parts Marketplace and see if I get any interest generated. I don't need it.
(quoted from post at 21:07:05 08/29/15) While digging through a bunch of boxes of carb and governor parts I found a brand new Zenith 13960 carb. Any idea what it goes to.
Hello Am looking for that same carburetor. Do you still have it?
You should start a new post of your own on this. This site uses two different views. People using Modern view will see your post and the original post you are tagged onto, so they see the "whole" story related to your post. People using the Classic view only see your post as "Re" to the original post, none of that original post since Classic does not bring old posts to the top like Modern does; they stay in the list where they were posted in time where you post shows as current. People can swap over to Modern to see the original post, but likely many will not bother to do that. I don't know which view bmack95hd uses, he may or may not see the post your tagged onto.
(quoted from post at 18:43:25 12/12/22)
bmack is still active, but appears to be a classic view user. i'd agree, a new topic is needed, and hopefully he'll see it.
