Oil Change ? Thanks
POPGUN
I had no idea I would get so many great replies on my syn oil post. Nobody said my theory would hold water so I wont try it. On my anti-freeze flush someone said that anti-freeze would create a acid and could cause a leak at the freeze plug. I do know that hard water or water ran through a softener will corrode the freeze plug. So I use distilled water and so far so good.
I always use distilled water (and anti freeze) in cooling systems.
Still, common anti freeze should be replaced every two years or so to prevent corrosion.
Dean
OOOOOH shoot Dean ya got me now------I didnt know that I just suck it up with a tester spring and fall if it test ok and is clear green its a--go at my house. Do you know how many gas burners I got, the newest is a 04 oldest is a 41 and they all have the anti freeze that they came with. I would need a bank loan at this point. But thanks you did you duty too tell this ignorant pilgrim.
