Walston
- Location
- Upstate SC
The one pivot pin on my jubilee had a lot of play. I was hoping that it was just loose on the inside, so I removed the axle housing (looks like a trumpet). As you can see in the pictures the pin in worn, but the housing is also.
My current thought is to buy a new pin, clean everything up good and use a high quality epoxy to fill in the gap in the housing when I install the new pin. What do you guys think? Will that work or do I need to find a replacement axle housing?
