kylemorley
What is the method of choice for locking the engine so it cannot turn while something like a crank pulley nut is being loosened or tightened? I know some rope down the spark plug hole has been suggested here but I have never had any luck getting the rope to go where it is supposed to on flatties.
Only other thing I can think of is pulling the starter and making a lock that jams the flywheel teeth but that seems like a lot of work.
Impact wrench will probably not work as the object to be removed has just a screw driver-type cross slot, in bad condition.
