Hello all fellow Ford Tractor Owners!!!! New member So be nice!!!
I have a ford 801 series select-o-speed, not sure of the year tho. The other day I was going to go hook up the two bottom plow and go plow a food plot for a buddy down the road for hunting. Well I get it hooked up and go to lift the plow up and it only lifts it about two inches off the ground. Well first off, the guide that stops the lever on the top we had to remove that bolt so we can go past to even lift up our roto-tiller. But in the past it hasn't been this bad. We replaced the hydraulic fluid and nothing same lift height. My father read the book and he messed with the float lever and the two bottom plow lifted up. I'm wondering if anyone knows how to adjust the lever or knows what is wrong. Also if anyone on here knows someone around the Flushing/Flint, Michigan that works on these tractors. I can post pictures later if needed for the year.
