pixer
this forum has helped me out with many tractor problems does anyone know of a forum like this that would help a guy with an outboard motor problem?. I have an old 20 horse motor that parts are hard to come by and expensive I would like to put a small electric fuel pump on it, i tried one for a jeep and it filled the cylinders it was too powerful. any help for this odd rquest would be appreciated. email me would be ok [email protected]
Mr. Gasket makes a low psi pump, I use them on mowers and buy them at Auto Zone.(cheapest I have found)
appreciate the information, sounds like just what i need, got a ball park figure of what cost would be?. is Mr. gasket the manufacturers name?
Not a foolish question at all Flip Mfg. makes a small eng. fuel pump 2-3 psi. and there are several others out there. Google is your friend.
If you continue to struggle with the motor, you might give the gang at Hull Truth a try (thehulltruth.com) The boating forum is knowledgeable and tight-knit and every bit as entertaining as this one. Between the two you'll find plenty of answers and no end of colorful talk!
Good luck--
