Good morning everybody. I have a question about the adjustments on the carburetor on a 12V side mount distrubutor 8N.
Before I took the carb apart I counted how many turns both screws were turned out. The main jet was 2.5 turns out and the idle jet was 2.75 turns out.
From reading I know the suggested adjustment is 1.5-2 for the main and about 1 turn for the idle. And that is what mine is set at now but it sounds like it's doesn't have fast enough idle or enough power when I drive it.
Should I set the adjustments back where they were when I took it off? Or is there something that needs fixed in order to have the adjustments set correctly?
I would appreciate and advice you are willing to share. Thank you!
