“N” Tractor 12V Power Distribution
whopist
In converting “N” front mount distributor Tractors to use 12V Chevy 3 wire Alternators I have always labored on where to put the extra resistor while keeping the 6V round coil; and, also the diode to turn off the engine.
This time I’m trying something new. I built a new wider Ignition Resistor/Distribution Plate. This gave me more room to add a fourth connector stud for the needed diode.
The second “step-down resistor” was simply mounted under the Plate on the existing screw.
Here it is mounted on an 8N Dash:
And here it is on a 2N Dash:
The only thing I might add is a sketch showing my wiring connections:
“Nice work but I have to ask. Why not just put a 12 volt coil on it and run it?
Rick”
Well, a coil cost $30 bucks and a resistor cost $6.
Also just my thinking; but, the 6V coil might run a little cooler than a 12v coil. Do you have any thoughts on the matter?
(quoted from post at 20:49:59 08/21/15)
Rick”
ertainly it will run cooler! Now about half the heat is outside the coil & in the resistor vs the 12v coil. A plus is that coil current is stabilized & will remain more constant than with a 12v coil. Like the stabilizing ballast in a ship.
(quoted from post at 17:49:59 08/21/15)
Rick”
OK just asking. I went with 12 volt coils on all my conversions.
Rick
I have a resister on my 6v square coil. I thought the original Ford coil would be of better quality than the new coils. I put my
resister where the cutout was mounted.
Neatly done! That's where I've been putting my diodes too.
I was torn between the vibration at the alternator and the
heat at the resistor but so far I haven't had any heat issues.
Looks a lot neater on the alternator end that way too.
Yes I'm old enough to know the old "run on start -- stop on run" of my 56 Ford. First year for 12v in Fords.
