Ford 2N Delco 10 SI Alt bracket
Go to ebay-search for 291253600742..I bought one for my 2n-cut off about 4" -bent a 90 where it needed to be to line up with the alternator bolt-drilled a hole where it needed to be to attach to the hole that was there for the generator spring loaded bolt..Works for me..and 1/3 the price
so easy to make.
even a uni fit from an auto store.. then get creative and use a water pump bolt as an anchor.
I made a small L-shaped bracket mounted to one of the alternator case half bolts that uses the later 2N tensioner spring unit. The nice thing is that this provides some "give" if the axle swings up and touches the alternator case.
