How Much RV Anti-Freeze
wsmm
I live in Mid-Michigan and am wondering how much RV antifreeze I would need to mix with how much water to weight each of my rear tires on my 2N. Right now I have one weighted with calcium and water and the other with windshield antifreeze and I want to dump my calcium and go to something different.
Thanks,
Bill
I don't have an answer for you.
Is the tube leaking now?
If not, i probably wouldn't change it just to change it. I would wait till i had a problem with that tire and do it then.
I used WWF in mine.
Waited till it was on sale and got it for $1.37 a gal. Of course a week later it went down to $1.27 but that's just how it usually goes.
RV antifreeze at over $2 a gal or Wiper fluid winter grade at just a tad over $1 a gal.
That said and these are the old number but a 10X28 tire holds 23 gal of fluid and a 11-28 holds 32 gal. The 10X28 is the same as the new number system of 11.2X28 and the other one a 12.4X28 if my memory is correct
I'm with ud. Change the solution when its time for a tube or tire, if not leaking.
This will give you a year to catch tv antifreeze on sale after season. Any pg should be non toxic, don't have to be tv. Also, doesn't have to be mixed like engine coolant. A bit slushy I tires is not a deal killer, you just don't want them solid.
JJ,
They were on my 4400 with 16.9X24s.
Online chart said 58 gal/tire but at about 55 gals they were spitting it back out with the valve at 12:00 so i called it good.
