Tall T
The heavy duty leading edge (thick blade too) was only held on by the two end bolts and was bent and bowed up in the center due to great slabs of dirt and rust. so I removed the plate and went after the surfaces with an air chisel, a large grindstone and then a cup brush on that large grinder I scored. I primer'd both the blade and the backside of the edge plate and then used Valspar Black.
Thanks to the previous owner, I had plenty of those flat headed, recessed bolts and despite the nonconformity of the two pieces, was able to pull it all flat again.
I cleaned up and painted the Jube running boards as well.
T
T
