IF one were frustrated with the poor overheating quality of the aftermarket key switches, would it be possible to cut the wires, thereby rendering the key switch unusable, and then tie the two wires coming off the terminal block together, thereby making the necessary connection? I understand that this would render the tractor "startable" at any time, unless other starting problems exist.
Also, my new coil doesn't sit as tightly as my old one. I've read in the 75 tips that there is supposed to be a gasket below the coil, but a gasket didn't come with the coil. Anyone have a part number for that gasket, or are you all making your own?
Thanks for your time.
