cousin was driving, 1/4 tank fuel, went around a corner, truck stalled, she pulled over.
i went out to look at it.
battery turns over starter fine. lamps and gauges work, I checked for fuse burnouts, found none on the panel just inside the door.
I pulled a spark plug wire and held it near ground and it has spark. I had to get back to work so I just towed her here.
I'm ?wondering? about fuel pump.
at key-on, I don't here any fuel pump charging up the plenum... but wasn't sure on this truck how that worked.
Ps.. this truck has lots of stuff that crosses with a ranger.
Also.. thru me off when i counted spark plug wires at first.
If this does have a pump that should be running.. is this a rail /frame mounte dpump or in the tank? and is there a charge pump under the hood?
thanks
thanks
