[b:1db2e33c59]Background[/b:1db2e33c59]: Seal leaks because previous mechanic didn't use permatex when he re-assembled it. I need to re-do the job.
[b:1db2e33c59]Problem[/b:1db2e33c59]: Bottom nut (see photo) turns stud so wheel will not come off.
[b:1db2e33c59]Question[/b:1db2e33c59]: What's the best practice to get the thing off? I tried to rotate wheel so the weight of wheel would pull the stud tight but that didn't work. I put some Blaster Penetrating oil on it - no go. I think my options are to cut it off or take off the big nut and pull the wheel. The last option seems a bit scary because I'm working in gravel. A nice concrete floor with a wheel dolly might be convenient - but I don't have that luxury. Ideas?
