Re: Ford I9-II7 Loader Manual
Is this the "jungle jim" loader? If so, there is a ring on the cross piece right in front of the operator eyes when sitting in the
tractor seat. The loader balances very well when lifted from the ring. Have to unhook pump drive and remove further after loader
is off tractor. Have used a tree limb, or other structure and a come-a-long to only lift slightly and then lower when tractor is
moved out of the way rearward. Remove four bolts at the rear and loader should come off the one or two pegs under the radiator.
Fenders can stay with the loader. Roll tractor rearward from the loader by hand. Do not run engine until pump drive is removed!
HTH
