Hi Folks.
I wonder if you could listen to this engine and tell me if you think there is an oiling problem. I just got this machine going after being stored for 8 years. The only think I've done so far is Points and plugs. it needs wires too. Carb was dry and clean when I opened it for a peek and I didn't do anything there either. There is a bit of a backfire through the carb so I have to look at timing but it's making a noise like a bad throwout bearing, but that isn't it. I hope you can hear in the video. (hoods off because i'm cleaning the tank out).
https://youtu.be/0XxGPAWwv-4
