Ok I have a 52 8n and I was mowing along then after a hour in then the hydraulics would no longer lift the mower, pto works good it feels like it's trying to lift but will not, the lift control lever gets a little harder to move when in the lift position, I took the inspection plate off and checked for leaks when lift is engaged oil comes spraying from the top lift cover, it's hard to really get a good look with the tire on, thar are also small bubbles coming from the center of the pump, any help would be appreciated. I also have all the manuals, early in the year I replaced the safety valve and piston with the leather and rubber o ring.
