BlackThumbHomesteader
That the filler neck on my radiator is soldered on. Was cleaning up a solder ball that was(try to) hold the relief tube on so I could put it back on more securely. I was using a screwdriver to scrape out the softened solder while my torch heated it up...and then the neck just clean fell off.
The upside is that I can now straigten up the filler neck and drill out the relief tube hole to accept a threaded line(2mm brake line in fact) before I get to put it back on. Won't be driving today, but every little repair makes the beast more mine.
