How much pressure is required in the 3 Pt lift system to lift an 800 lb load? From what I have read 800 Lbs is about the max an 8N could lift without bringing the front wheels off the
ground. The reason I ask is in line with using an aux pump to supply live hydraulics through the test port fitting, as in how much pressure is actually required for normal lift use. What
would happen if the aux pump used only put out 1000 or 1200 psi, would the lift be super slow, or not work at all? If the relief valve cracks at 1500 psi then an aux pump would be
running in bypass most of the time if it supplied more than 1500 psi. Has anyone run a pressure gauge on their aux pump while using the lift?
