transmission, stuck in gear
(quoted from post at 08:57:12 07/26/15) Not enough information to say anything. Will not move is not the same as stuck in gear.
Sorry, he was trying to dig a hole with box blade in very hard ground/tree roots. Going from reverse to second back and forth, stopping each time to change gear.(maybe changing to fast) Then it just seized up wouldn't go in or out of gear. Engine starts and runs fine, but will not move/change gears. Feels like it is up against a tree and just can't move. Hope this is more helpful. I have never used this forum before, and he can't use computer. But he can take an 8N apart and put it back together. He did take trans. cover off and looked in but can't see anything. Any help would be much appreciated. thanks
So your saying he can put it in gear not move forward or backwards right?? If yes then with the transmission cover off and engine running does the input shaft turn in the transmission?? If it does then the clutch and input shaft are likely to be good so may have broken and axle or stripped out one of the rear wheel hubs. When in gear and engine running have some one see if either rear axles are spinning but not driving the tractor. Or it could also have a ring gear on the rear end stripped out
you are still not being clear.
with it setting there, running, will it STALL the engine if you take your foot off the clutch.
If no, if it does not stall the tractor, then it is not stuck in 2 gears.
If in fact it will not move at all, and will not stall, it is not stuck in ANY gears.
post back some CLEAR, CONCISE, SPECIFIC info.
Does the pto work?
( reason for these questions is that if the trans is ok, then there may be other driveline problems in the rear like ring gear rivits or trans to pinion coupler tube. )
I'm sorry it has taken all this time to get back to this. I'm doing this for him.
1. he pulled the stuck tractor 2. he used a pry bar on the trans. to unstick it. 3. then there was a PoP. 4. Now it will drive but there is a popping in trans.
I will try to be more precise, this is what he told me.
THIS WHOLE PROBLEM STARTED BECAUSE HE WAS ROCKING THE GEARS WITHOUT COMPLETE STOP.
(quoted from post at 10:16:19 07/26/15) Can he let out on the clutch when the engine is running or does it kill the motor?
No, didnt kill motor.
He pulled tractor, then he used pry bar on gears, then he heard a POP, It drives now but trans. makes noise.
Not sure if this is clear enough this is what he told me.
