rebuilt pump but no muscle
realman
New User
Jubiliee 1954? Just rebuild the hydraulic pump. Has 400 lbs cold 220 hot pressure. Was lifting weight at first but now only lifts no weight. any suggestions.
(quoted from post at 11:06:45 07/24/15) Jubiliee 1954? Just rebuild the hydraulic pump. Has 400 lbs cold 220 hot pressure. Was lifting weight at first but now only lifts no weight. any suggestions.
o load = virtually no pressure. Pressure is proportional to load being lifted.
(quoted from post at 08:06:45 07/24/15) Jubiliee 1954? Just rebuild the hydraulic pump. Has 400 lbs cold 220 hot pressure. Was lifting weight at first but now only lifts no weight. any suggestions.
Vane pump (the square one)?....could be worn out...the clearance are tight and there are no new parts for them.
TOH on this board sells an adaptor to use a modern pump if your vane pump is worn.
-Dave
