48, 8N, 6 volt, front mount.
Last week the wiring harness started to smoke JMOR helped me with it. I had to replace the ignition switch, coil and moved the positive ground wire to the engine block.
Now, the tractor will run for 2 or three seconds and then die. It will start right back up only a few seconds later only to die again. I switched out the condencer (just to check), and tried it with the same results, then I took off the gas cap off just in case it was vapor locked (same results).
Heck if I know......
