Still attempting to get charging system up and working.
43 2N 1 wire.
Replaced the non-working innards of the cut out can with bridge rectifier.
Verified power going only one way. Put cover on and verified not grounding out on cover.
Installed same way as (borrowed) picture shows.
Went to hook wire to genny and got a spark.
Checked genny with continuity tester, there is continuity from connector bolt to case.
I have 6V on wire at genny connector.
Checked old genny with same result. Is this right?
Is it possible it is wired in backwards? It's the only thing I can think of.
I'm sure the next one I do will go faster lol
Thank you for your knowledge sharing,
Norm
43 2N 1 wire.
Norm
