will a set of 801 lift arms will work?
upper arms? as in the ones that are splined and slide on the the rockshaft.. The 801 are held on with a plate with one
bolt the 8n has a plate with two bolts.
If you are talking about the middle arm the 801's are 4" longer and are positioned about 2" further back on the lower
arms. Could you make it work and live with it, anything is possible, but it's up to you.
Kirk
its that there cylindrical thing with splines on each end that goes thru the top cover and has an upper lift arm on each side. ;)
