3 point hitch not working
Edgehill
:D Thank guys for all your great advice, when you mention the spring, I back off the nut on the draft control lever and tap the handle so the friction pad was not working. And removed the stopper as well,and doing so I found it spring all the way to the top!. Started the tractor and the lift arms raised and lowered perfectly. Iam so pleased with the results and learned a lot about hydraulics on the Ford N tractors. Thank you again for all your info on this forum. Best regards/ Edgehill
Glad to hear you got it back up and working.
It's always nice when it's something fairly simple and cheap!
