Nicholaus Sowder
Hello I need some advice about a customers Jubilee. It has been converted to twelve volt. I think the ignition switch is no good. The question is the current ignition switch has three wires coming out the back of it, the one wire appears to have never been hooked up to anything. I have looked online at new ignition switches, it seems like they all are two wire models. Do I need to get a three wire model and figure out where the third wire goes? I think that an ignition switch does care whether it is twelve volt or six volt am I thinking correctly? I tested for spark by removing each spark plug wire one at time while the customer cranked the engine over while I held a spare plug which I put into each boot and it against the spark plugs which were still in the head. I am going to get a new ballast resistors and try it because they are not that expensive. I did not have test light or volt meter with me. I should have brought one with me. Thank you for and all advice
