For those of you that read the previous posts - I installed Petronix electronic ignition and the same time that I rebuilt the entire engine. I couldn't get it started, but seemed like it wanted to fire. I removed the electronic ignition and went back to points. Sounded exactly the same.
So I was questioning if I got the timing gear installed correctly.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto24274.jpg"/>
I'm not sure how well the timing marks on the timing gear show up. There is a X on the timing gear by the crankshaft and a hash about 180 degrees opposite the X.
There is also an O on the crankshaft gear that doesn't show up. It is located at the base of tooth above the X.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto24275.jpg"/>
<image src="http://forums.yesterdaystractors.com/photos/mvphoto24278.jpg"/>
Have I done something wrong here with the timing?
