Installed new cut out, energized system, started tractor,amp gauge moved,
WOOHOO,it works. Only problem was gauge moved to discharge upon start.
No problem just switch wires on gauge.
Shut tractor off, and OH MAN, gauge goes other way well past zero.
Tap can, needle moves to center.
Switch wires around, start her up and needle heads to charge, about 15 amps.
Shut down and needle moves to full discharge, tap cap can, needle moves to center.
Any suggestions beside calling company bought from?
Is can openable to see if spring is hooked up inside? Is there even a spring inside?
Thanks, Norm
Thanks, Norm
