Lokel Yokel
Everything was fine before the paint job....
Now I've got no spark.
Tractor cranks good so I think my positive ground is good.
Power is reaching the resistor. 8 plus volts. (8 volt battery) Resistance is about 2 ohms. Voltage output from the resistor looks to be 1 volt!
Wire is good from resistor to coil.
Can I bypass the resistor just for testing purposes? Is that resistor faulty?
