BlackThumbHomesteader
This is going to be a project thread, documenting my progress refurbishing the shift gate and shift lever of my 51 8N.
The beginning;
Was heading out to mow some acres and upon shifting into second the tractor would not move. There was no grinding or thunking, the wheels just would not spin. The shifter was loose and would just flop around without engaging any gears.
I removed the top plate and found that the forks and plates would move through all gears and I could turn the them by hand untill they fully engaged. The clutch freeplay was adjusted and I was able to stomp the clutch while in gear and could then turn them by hand once more. So, no damage to the gears, plates, forks, clutch, or wheel hubs; just an out of spec shifter.
Upon examining the shift gate whilst still installed on the top cover I noticed chipping, pitting, and grit trapped in the spring and fingers that helped cause the wear to the shift gate. I drilled out the four rivets holding the gate and found that there was a large amount of grit trapped in old, hardened oil that was acting like sandpaper. I suspect sitting in the rain and a bad shift boot to be the root cause of the problem. This tractor was obviously ill used for years and had been sitting for quite a while before I purchased it.
http://imgur.com/a/sgzc0 shows the rounded fingers on the gate as well as the pitting on the shifter. I did a quick clean up with de-greaser and a wire wheel. I think the shifter is not so much a problem as the shift gate is. I'll be adding weld material to the fingers and then filing them back into proper shape which shouldn't take more than a couple hours. I'll hit the shifter itself with a bit of material as well to fill in the small worn area just as a safety measure so I don't have to pull it out again.
Continued once I've gotten to the welding.
The beginning;
