tarletontexan11
New User
This may be a very easy question for some of you, but i am not near as familiar with all the little differences of these tractors.. As said in the title, I am in the process of rebuilding a 2N (nothing pretty just need a tractor to mow, drag arena, etc...) and have put what i believe to be a 8n exhaust manifold on it. It was laying around, and free. It's larger in size and now the throttle linkage is not long enough to go WOT. Im only getting about 3/4 of the throttle, and because it's in a bind, it keeps popping off. My question is, is the main throttle control arm (runs horizontal above engine) different on an 8n, as in it will stick out further to clear the manifold, or is the linkage running from that to the governer longer/bent to accomodate? Or Both? Thanks for the help.
