Skeeter102
I pulled the top cover and replaced the piston with the naa piston. I also replaced the cam follower pin, friction disk, and safety valve. I used zane's jig and I think I got everything in spec. Now in position control (lever up) as soon as I start to move the quadrant lever down, the lift starts to fall immediately. In draft control, the hydraulics will not raise at all. So, I adjusted the plate on the quadrant back some. The lift now seems to work in draft control but position control still does not seem to work right. Once you move the quadrant lever a 1/4 of the way down, the lift drops.
There are no leaks anywhere when looking through the top cover.
What did I do wrong?
