47 8n that is hard to turn , I have centered the steering wheel and positioned the sector arms slightly angled back. Steering seems smooth and no noises while turning the full range left to right. The steering wheel has some play , it will move from 12:00 position to 2:00 before the arms move. I tried rotating the eccentric covers and it made no difference. The steering wheel does not raise or lower when turned or pulled up on. The arm on top of the spindle that the drag links fits into is bent up 3/4" compared to my 48 8n that steers fine. Question is , would that make the tractor hard to steer and if so can I put the arm in a press and straighten it ? I'm not sure if it's cast or forged. Oh yeah , both sides are bent up.
<image src="http://forums.yesterdaystractors.com/photos/mvphoto23426.jpg"/>
