Canister Coil with Resistance
rustyal
Just went to autozone and picked up a coil. LU800
The exact same coil I bought at Napa. IC14SB had
to buy a new one. The plastic broke around the
terminal while removing the nut. Cheap made piece
of junk. But they work. Just don't need to remove
the nut!!
" The exact same coil I bought at Napa. "
The internal resistance of the NAPA coil is 3.25 ohms or a bit more.
What's the internal resistance of the AZ coil?
75 Tips
(quoted from post at 00:32:39 06/22/15) " The exact same coil I bought at Napa. "
75 Tips
Duralast® (Autozone) LU800 3.3 Ω primary resistance, 8.3K Ω secondary resistance (oil-filled)
Wells® LU800 3.3 Ω primary resistance, 8.3K Ω secondary resistance (oil-filled)
Part Number: LU800
Weight: 1.35 lbs
Warranty: 2 YR
Coil Can Diameter (in): 2.2
Coil Can Height (in): 4.7
Coil Can Overall Height (in): 5.69
Coil Color / Finish: Black / Plastic, Metal
Coil Configuration: Conventional
Coil Terminal Type: Male Connector / 4 Male Blade
Coil Wire Terminal Attachment Type: 1 Female Spark Plug Cable And Boot
Inductance (mH): 11.3
Item Grade: OEM Standard
Minimum Primary Resistance Range: 3.4 Ohms
Minimum Secondary Resistance Range: 7,900 Ohms
Package Contents: Component, Hardware
Vehicle System Voltage: 12V
Price: $29.99
i forgo the ring terminals now, and just use the lil spade tabs. much easier to use when checking or swapping stuff.
