Royce - Hooks on Jubilee front axle
BigYoung
Royce, could you post a close up of the front axle hooks and tell us what I parts I need beside the hooks to duplicate your setup?
yes , please royce . thats a cool idea and you have allready worked it out so i would like to steal you idea .
Will do guys. It's setting down at the fair grounds right
now so I can't do it today, but I'll get them for you.
I assome you are wanting to put some tie down hooks on your tractor?
A few years ago I went to the big boy rigging house and bought a pair of grade 8 eye bolts.
The threads are 5/8 - 11 so they fit through the holes in your front axle.
I can slip them into the holes and put a nut behind them. OSHA approved for over head rigginng. They weren't cheap but do work well.
That's what I used on mine too Jerry, then I added a double
clevis mid link and attached a hook so I can drop a chain link
in it anywhere along the length of the chain.
No. 11 is the TPI (threads per inch)
My tractor is 115 miles away from here so I can't measure the length for you.
Just measure the thickness of your axle and add at least 3/4" for the nut.
I wanted to add a flat washer to each side to minimize scratches
and a lock washer of course, so I went with 6" length. A bit long.
I forgot to take a picture today, sorry about that. :oops:
Might check the address below too. It wouldn't let me link it.
https://www.boltdepot.com/Forged_eye_bolts_with_shoulder_(w__nuts)_Hot_dipped_galvanized_steel_5_8-11.aspx
If you're looking at show quality/trailer queen material, a felt washer that's used on battery terminals will protect your paint ever better.
That sounds like a good idea too Ron.
This one isn't quite show quality, but it is a trailer queen.
At least for the most part. They seem to run better if I work
them a little. Even if it's just grading the driveway.
