Carb kit part numbers
oldtanker
NAPA sells a complete kit that includes Throttle/choke shaft with screws. throttle shaft seal, needle, seat, float pin, choke plate spring, jets, sealing washers, gaskets, choke pull off spring and main and idle needles. Part #S.66893. Price is way higher than on here by 20 bucks or so but if you need it next day I guess the 20 is worth it.
Rick
Convenience comes at a price...
If someone is willing to pay me to stop the show and put them at the front of the line for there Convenience I can be brought...
(quoted from post at 14:49:41 06/19/15) NAPA sells a complete kit that includes Throttle/choke shaft with screws. throttle shaft seal, needle, seat, float pin, choke plate spring, jets, sealing washers, gaskets, choke pull off spring and main and idle needles. Part #S.66893. Price is way higher than on here by 20 bucks or so but if you need it next day I guess the 20 is worth it.
Rick
That Napa number is a Sparex number. I noticed a while back that Napa has started selling a lot of Sparex parts.
The ones sold on here used to also include new brass retaining
rings to hold the seals in and new brass plugs to plug the end of
the shaft holes once you have taken the shafts out and cleaned
the bores. The last few I've gotten have not. :(
This is a Jubilee carb, but you can see one of the brass plugs.
