Help with part number
When working on getting the alternator on my 8n, I discovered the Rear Cover Plate on the water pump that has a bolt hole for the adjusting bracket was broken off. I pulled the water pump to get a better look at what I needed or it if could be repaired somehow. There is enough room to drill another hole in the plate but since I have it off I might as well do it right. I have found the gaskets that I need but can't seem to find the plate without buying a water pump. Anyone have a part number for just the plate.
Thanks
You've been around here long enough that you're no longer a newbie; time to buy a parts catalog.
Page number 108, part number EAF 8508-A.
Good luck finding one.
Try these guys first:
John Smith smith8NATatt.net
Rod Mondor fltractorATpeoplepc.com
Replace the AT in the address w/ @
Rod forest lake tractor 651 464 4628
75 Tips
