Hi ya'll.
I have been searching the archives here for a while trying to get this figured out:
My friends 9n had a loader on it before they bought it. It has a washer welded over the cut out for the shaft to the front pump, and the crank pulley has 6 holes, 4 of which have bushings in them, though no threads I can see.
I found them a wagner for $200
I have the 6 point shaft, I'm wondering if this crank pulley with bushings can be bolted to the 192161 hub that receives the shaft and bolts to the crank? I need to know how the check the fluid level and top off/replace etc, if anyone has a link for that procedure.
thanks!
thanks!
