Removing seized frozen brake drum off 8n ford
Sclem
How do you remove a rusted & seized brake drum off a 8n tractor. Been setting & rusted for years. Thank you for any help.
Are the retaining screws out?
"Loosen Juice" and lots of tapping on the mounting face between the studs and more "loosen juice" should free it up. Or a few cycles of heating the area with a torch, allowing it to cool to ambient, and repeating.
As Bob said.
If that doesn't work take an angle grinder with a cutting wheel and cut it off.
Cut it in half like a piece of pie then slug it with a big hammer and crack it off.
Then buy a used one.
N parts are cheap and plentiful.
Good advice so far! I also try to back the brake adjuster off first.
Not always possible, but I try.
As for the tapping on the front side between the lug bolts, I have
found that I'm not a real good aim with a hammer anymore and
I have the thumb nails to prove it! So what I do is set a ball peen
hammer on the surface where I want to hit it and then rap the
back of that hammer with a dead blow hammer. Slower, but it
seems to work well and saves the studs.
