Hey... I have a 51? 8n and i just put a complete transmission in it (4 speed) as gears exploded. I continued to drive in 1st (only gear that worked) until i split the tractor and installed a new trans. While it was apart it must have gotten some water in the clutch and it seized up (had to re-split). I removed the flywheel and installed a new starter gear and had it resurfaced. I installed the new clutch, pressure plate, throwout bearing and pilot bearing.
New updated clutch has spring dampeners whereas the old one didnt. Old one had TONS of pad left but it seized to the flywheel.
After installing the new kit i adjusted the pedal almost all the way tight and tested.. No go.. Clutch wouldn't disengage. Kept adjusting til adjuster is litterally bottomed out and now it works but barely.
Something doesnt add up here. With my old clutch it was half way adjusted not all the way.... I just dont get it.
Any advice? Clutch is installed correctly (as in long side vs short side)
