TJ in KY
I have a 1950 Ford 8N tractor that I have been working on for some time. Last year I put it all together and tested it prior to painting everything worked good, oil pressure good, hydraulics good no leaks or leaking off, etc. but I noticed the rear wheels have some play in them as I was taking it apart to prep for paint.
I had put new bearings on the axles and the differential and shimmed it according to the manual and after reading John Smith tutorial on the axle shimming. The wheels turn in opposite directions but I have play in it when I grab the top of the tire and move it in and out like when you have play in a front wheel bearing when it is loose.
Could it have loosened up in the 8 or so hours I ran it mowing with a finish mower?
I am just wanting to confirm it is a shimming problem before I take it apart. Also can the seals be reused or should I get new ones. Both sides seem to have play. Will shimming one side correct both or will I need to take both sides apart and start over.
