Lower link shaft replacement
jkeller8n
New User
I had a bad leak from the lower link arm shaft on my 8N, so I pulled the left trumpet and differential and removed the shaft. I ordered a replacement shaft, however the replacement doesn't fit flush with the hole. Is it supposed to, or should I just tighten the castellated nut to 150 ft/lbs and call it good?
Also, is it just me or is the hole for the cotter pin quite a bit too high for the castellated nut? Think I should stack some more washers? Or drill a new hole for the cotter pin?
Thanks in advance,
Justin
Don't remember them being flush when new. I would get another G8 sae flat washer and put on if think cotter hole is too high.
I have never had to remove mine, but is that not a tapered pin? In which case it would not fit flush.
I too would add another washer under the nut.
It is a tapered pin, my brain just wants it to fit nice and flush I guess. That's what I'll do then, just add another washer or two until the castle nut is at the right height with it torqued down.
Thanks guys.
Justan.........dunno where yer mechanical aptitude is...but...just bend the SOFT cotter key to fit yer castellated nut slotts. Simple, eh? ........the amazed Dell
(quoted from post at 16:47:58 05/17/15) Justan.........dunno where yer mechanical aptitude is...but...just bend the SOFT cotter key to fit yer castellated nut slotts. Simple, eh? ........the amazed Dell
Huh, I suppose that would do it, wouldn't it. Seems like I might have been over thinking it a bit. I guess the cotter pin should hold the nut from working loose even if the cotter pin isn't sticking directly through the crenellations.
Thanks Dell.
